4 12"s VS 2 18"s
Well I did a 149@44hz off the 2 18"s off approximently 3300-3500 watts. So what do you think 4 12"s could do off about 5000-5200 watts
Just curious. Are you competing? Or just want something louder just because?
Just wondering because I see you still have stock everything except subs, which could be pretty overpowering if trying to listen to daily.
Towards your question though. The 18's have a ~56 sqin advantage on the 4 12's. The 12's though will have 2000 more watts you said, and more motor to dissipate the heat. I don't think you could lose much if any. More than likely you'll gain because of the 2000 more watts.
Just curious. Are you competing? Or just want something louder just because?Just wondering because I see you still have stock everything except subs, which could be pretty overpowering if trying to listen to daily.
Ya its for competing. I am also thinking cause 4 12"s will keep me in SB3 as oppose to 2 18"s being in SB4
Gotcha. Yeah, my vote goes to 4 12's. What subs are you looking at?
There was a guy on here that has a red explorer and ran 4 HDC's. I can't think of his name though...shi t. He had a vfl 500.1. Brain fart. I'll think of it and be back. That is pretty similar to you though.
EDIT: Skip01.
Skip01? with the green explorer and 2 500.1's
not exactly you just took the area of 2 18" circles and 4 12" circles when the effective piston area is never the size of the driver. 12's are "typically" 480 cm^2 and 18's are "typically" between 1050-1200cm^2
i do think your right about being louder tho, 4 12's would "hopefully" push you into that magic 150db not by much, but should get you to 150-151 territory
Why does everyone think I am going with AQ? LOL They will be RD alphas if I do the 12"s
well sound quality is opinionated, although ive heard the alphas have besster SQ, as far as SPL tho, there was a test VERY resently done on the boards between the alpha and the hdc3, and the hdc3 was louder on the same wattage.
if you like your alphas stick with them, they say if it aint broke don't fix it. just lettin you know was all.
mazzasec
Banned
mazzasec
ATL
jdmferio13
