3sixty.2 Help / Question
Exo5168
Just a quick question to you 3Sixty.2 owners.
I hooked this up last night and have not run my setup yet, but out of curiosity when you first hook it up, is the sound level pretty low? I bypassed the 3sixty straight to the amp, and I had a lot of volume, as my gain is up a bit, but when I go to the 3sixty.2 in and front out from there to the amp, the volume is down quite a bit, and I can see the "clipping" monitor on the unit hitting in and out with a blue light when the volume is up high on the head unit.
I am just hoping it's just because I need to set up the 3zisxty.2 and not something I did wrong .... will be getting a bluetooth adapter tonight.
The initial set-up takeS care of voltage matching and will also set "volume" based upon you setting your head unit to highest level without clipping, then setting the 360 to just before clipping (flashing red). Until set-up is complete you won't have normal responses you would expect. I just did this on Monday myself...don't worry. BUT, BE SURE TO HAVE YOUR COMPUTER OR PALM CONNECTED VIA BLUTOOTH TO THE 360 BEFORE RUNNING THE SET-UP - OR EVEN TURNING IT ON.
Exo5168
Exo5168
Fort Worth, TX
gsa1
vegang
vegang
