3rd box for the D6 1.25 @35 hz ~**pix**~
acold7dusta
y they stealin my bucket?
well i decided to follow diamonds recommendation for my 10" D6 dual 2 ohm sub. its 1.25 cu ft with 2 2 -1/2" ports that are each 16" long. the curve starts at 30 hz (o db) peaks at 35.4 hz (+6db) and goes to about +2db @ 40 hz and slowly goes down to +1db 44 hz and up. its more of an output box, and should be miles away from my shitty .6 cu ft sealed box i got currently.
first time using titebond, we'll see how much i like it
guess my school books were worth the money after all:laugh:
time to get back to work, ill have more as i complete it
got a couple more sides glued down
(top was just resting)
seam
"top" glued on-thats where one of the ports will be, i gotta screw around with sketch up to see possible clearance issues with the other port
pail of water FTW?
progress so far, the wood layin down is the back panel
who luvs d' cawk
this glues a bish to work with
thats it for tonight, tomarrow ill cut the holes and caulk the backing, and run to home depot for the PVC
acold7dusta
acold7dusta
buffalo, NY
acold7dusta
