358 vs. 383
Which will you choose?
  • 355
    Votes: 7 18.4%
  • 383
    Votes: 31 81.6%
  • Total voters
    38
bigger is better........plus a little more stroke
offers more torque for that heavy truck,the cost between the 2 motors is neglagable
I would buy an Eagle assembly or similar and build it myself
Get the block bored to match the new pistons,new cam bearing,check the deck etc
freshen up the heads and have em upgraded to screw in studs and SS valves w port match
Cam and lifter kit from your fav cam grinder,all new ARP hearware
and buy the "How to rebuild your small bock chevy" book
Dood,with everything machined you can build it in a weekend in your garage
what yor budget ?Carb or EFI ?
I have done this only about a a dozen times for myself and friends
bigger is better........plus a little more stroke offers more torque for that heavy truck,the cost between the 2 motors is neglagable
wow thanks for the info i ll look into that book right now.
350 bored .030 is a 355, .040 is a 357, and .060 is a 360.
I've had 350-406's, including seevral 383. In a heavy vehicle, torque is king. You don't have the high revving like a non-stroker motor, but you make gobs more low end torque.
If you have Vortec heads, I bet 906 castings, you'll need them rebuilt and set up for a decent cam, up to at least .500 lift.
Then a good street cam for a 383 is a comp XE268. Good idle, yet gives a broad range of torque, and you can use stock converter.
A 383 and be sure to use the 5.7 rods, do use the 400 shorter rods, get at least 5.7's.
No need for forged pistons, etc, just use hyper's.
i think this has pretty much mad me decde on a 383 so far. ill give it a few more days tho
Of course we would decide on a 383. We're not the ones paying for it. If i had the choice of a 383 or a 355, I would choose 383 everytime...
The difference is, you are the one that will be paying for this, and whether or not you can afford it should make your decision.
i cant afford it all now, but thats y i still have an engine in the truck so that i can drive it and work on it while still having an engine to build up. so i can take my time and get the funds together for it
do some more research,buy a few hot rod magazines
and come up with a budget.......
U might aughta redo some driveline components too,******,conveter(looser)
gears........to do it right many things come into play to do a basic rebuild
and swap is a little more boring but cheaper.......
the good news is a SBC is the least expensive motor to build with something for
every budget 1200 and up...
How fast ya wanna go = how much money u have
jeeper07
Rebuilding&Reconstruc ting
jeeper07
Indianapolis, IN
SCIVIC94
