3500-4000 Watt RMS Sub Help?!
Just Ordered a Mechman 370 Amp alt & A Bc3500 D, Says It Does 3800 Clean RMS On 13.8 V, I Need A 3500-4000 Watt RMS Single 18" Sub That Can Take This Amp, I Checked Into EMF Audio's YOLO 18 It Seems Like A Beast Sub But Im Still Unsure, Any Other Sub Suggestions would be appreciated, Thanks. also Budget Is $1200
Just Ordered a Mechman 370 Amp alt & A Bc3500 D, Says It Does 3800 Clean RMS On 13.8 V, I Need A 3500-4000 Watt RMS Sub That Can Take This Amp, I Checked Into EMF Audio's YOLO 18 It Seems Like A Beast Sub But Im Still Unsure, Any Other Sub Suggestions would be appreciated, Thanks.
What vehicle ? Im guessing u have room for a 18 ...id go with the hdc4 18 ..but im biased lol. But it will take that power fine and cant be beat for the money imo
Wait for the Sundown Team 18 subwoofer. Although not sure 4000w is enough to move it. I think that speaker would be epic to own.
If not try for the Nightshade.
Yes, they do. As for the Taramps remote control, it is for use with the EQ they sell, not as a remote bass knob. They are not very sophisticated...
24
4K
  • Locked
Up for grabs is a Gravity Warzone 4000.1 mono amp. This is a solid low budget sub amp that does a solid 1000 or so watts at 1 ohm, maybe a bit...
Have you tried connecting the amp to a car battery? No subs, just power. If it protects, amp is bad. If no protect, subs/wiring or ATX power...
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
AARKing419
Toledo, Ohio
mylows10
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
