3000 watt amp recommendation
hone
Hello all,
I've got a 15" icon on the way and am looking for an amp to power it. I got the D1 so I can wire my single sub at 2 ohm and go to 1 ohm if I get a second.
This is why I'd like amp that puts out roughly 3000 watts at 1 ohm and around 1000-1500 at 2 ohm. Under $1000
I will be upgrading alternators and adding a second battery. I've been browsing ssaudio.com but some first hand experience would be nice.
Hello all, I've got a 15" icon on the way and am looking for an amp to power it. I got the D1 so I can wire my single sub at 2 ohm and go to 1 ohm if I get a second.
All of the SSA amps are very similar in board design and its a very reilable design. I doubt you'll go wrong with any korean board amp. It will go down to your budget mainly.
Yeah I'd be willing to go up to $1000. Edited first post with budget.
I could just get the one closest to my budget but I was wondering if there were any in paticular that stick out as good bang for the buck. I guess the DC audio 3.5k is closest to maxing out my budget.
The new sundown scv3000d looks good at $799 too though.
soundqubed 4500.1 is a good choice too man.
IA20.1... Hope you plan on beefing up your electrical in the very near future!!!!
Upgraded the stock battery to the largest AGM I could fit and did the big 3 so far. I'm planning to run the single 15 this way. I'll upgrade the alternator to a 220A and add a second battery if I get a second 15 and run the amp at 1 ohm.
This looks like the best bang for the buck. Direct from soundqubed they're $799 right now. I'll have some head room to play with which will be nice. Going to have to keep the gains dialed back until I finish upgrading the eletrical system.
Thanks
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I...
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
But since you guys are still here, I have another question. Now that I have a 3k amp, after I get my new battery and HO Alternator, I'll be in the...
272
20K
hone
hone
hercules, ca
Jeffdachef
SPLBassJunkie
    May 21, 2024
    May 20, 2024
