Depends on the fuseA 300A fuse will not blow until about 600A is passed through it for a second or so.
That is how they are supposed to work. If a given fuse does not work that way, they are not good fuses. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gifDepends on the fuseThis is why I hate fuses.
Roughly 4200 Watts. Power = Voltage x CurrentHow many watts can this fuse be able to take before going out?
Thanks,
Correction, your voltage will be 15.3V BEFORE your amp is pushing power //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gifI got my fuses from Knuconceptz. I will be using a Sundown 3000D at 1/2 Ohm with a MLA module so the voltage will be roughly 15.3 Volts.
Depending on the max output of your alt, it will surely dip well below that 15.3V //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
You'll find out.I know that but I just wanna know if the fuse will blow if I ran 4500+ Watts?
