3 way setup...
PaLiAcH
for a 3 way component setup (tweeter, midrange, midbass), how many amps are needed?
do i need one 2-channel amps for the midrange and tweet, and one 2 channel amp for the midbass?
or can i use just one 4 channel and and power all of them?
thanx for helping a newb out!
checkin out specs, i see that i will get more power by getting 2-2 channel amps as opposed to getting one 4 channel amp
obviously i would spend a lot more $$$ by trying to get comparable power out of one 4 channel rite?
Ah...that's right, I remember you now //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Yeah, I would check with Alpine and see if you can't just run that 6.5" midbass off the the same xover as the 4" speaker (since it says "3-way ready", and I couldn't find in the manual where it talks about it). Save yourself some money that way and only have to buy a single amplifier.
But, if you can't wire the 6.5's to that 4" xover, then you will need atleast 4 channels, which you could use a single 4-channel amplifier for.
PaLiAcH
PaLiAcH
SoCal
squeak9798
