3 subs in a box
White Rider
So due to my limited space in my single cab pickup i have 3 kenwood shallow subs. I am about to begin to build a box to go behind the seat and i have some questions. First is there a reason why i never see anyone with 3 subs? Can one amp power all 3 of them efficiantley? Also will porting make a big difference in the sound of these subs? I have an idea for external porting so i dont take away from the cubic feet space inside the box. And if i have a bit more than the recommended cubic feet of the box will that be better or are they tuned at that air space? And the length and space of the port is going to be a little different, does that make a big difference in the air exchange? There will probably be plenty more question but any information the you have would be great. Thanks
most of the reason for have 2 or 4 versus three is because most people like whole numbers versus decimal points when figuring ohm load
shallow subs=sealed.
Really? I have heard that but i also have seen a shallow sub in a poted box and it did hit hard.
Also these subs are a 4ohm sub...and the amp is a RF 500 mono that puts out 500 at 1 ohm. Im very new to amps and dont know what that means. What does that need to be at to give the subss enough power? or do i need to match the ohms?
Id divide it.
500 watts @ 1 ohm means your amp will put out that much when it see's that ohm load. Most amplifiers put out more power at lower ohm's. PG Xenons and JL slash series are regulated and put out the same power from 4 to 1 ohm.
Wiring 3 4 ohm DVC subs would give you a 2.66 ohm load, IIRC.
2 subs would give you the most power out of your amp. but power may not be the best bet vrs more surface area. Someone else MAY be able to answer that.
My friend was running 3 audiobahn 4ohm dvc subs off of a kicker 600.1 [600 watts at 2 ohm's.] and it hit pretty hard.
So runnin my amp at 1 ohm to all 3 of my subs would be the best; worst; horrible idea? Im just not sure what to do. The amp is 250watts at 4ohm, 400watts at 2ohm and 500watts at 1 ohm. Im unexperienced at elecronics right now and really have no idea what or even how to do this.
Amps just don't have ohm switches. Its all about wiring. Heres how i think of it. The better and more efficient you wire them the less ohms and more power.
I'm sure someone can explain it way better than i can. Thats an easy way to understand it.
So you mean by using....say 4 guage wire you could run more power than 16 guage wire? Or is there different ways to wire that make a big difference in the power?
No, he means by wiring the subs together. This has (for general purposes) nothing to do with the gauge of wire that you use.
Refer to what I posted above. This is what you will want to do.
White Rider
White Rider
Hermiston, OR
Alex JB
