3 kicker L7 10" box help
MasterBlast
ChevyForce94
468
IL
I think i have made up my mind and im going to get 3 kicker 10" L7. Im need help in a box for them they are going to be going to be in the middle of my truck bettwen the bucket seats. I would like to have the first one straight up looking towerds the top of the cab the next one angled alittle facing the front widow and dash and the last one angled more back and facing the front window to. I would like to know if this is a good idea or what and if there is anyother way for a box that would be better let me know. The box is going to be three chambered of course and sealed. What should the c/f be for each box for best sound and bass for the subs. There is only going to be one amp runing these for now which is the kicker kx1200.1 the subs will prob be a little under powered for awhile but o well 1800 watts rms on a 1200 amp that runs diff at diff ohms. Subs prob going to run 2 ohm
not sure on a suggestion for box design, but you can always do away with the 3 chamber idea to save some space and just use a single sealed chamber for a three, wont make a difference unless you blow one of the subs which i doubt will happen if your smart
about the amp i would if possible run it at 1ohm (not sure on the l7 vc configs) the 1200.1 is a nice amp and puts out loads of power and should be nice on 3 of those. At 2ohm you wont get much out of it imo.
MasterBlast
ChevyForce94
MasterBlast
IL
Strecker25
michigan born
    May 14, 2026
michigan born
    May 14, 2026
