3 kicker cvrs
your going to want the dual 2 ohm if you get 3 of them. That will give you a lower ohm load then a dual 4. Three dual 2 ohms will wire down to 1.34 ohm and three dual 4 ohms will only wire down to 2.67 ohms
I wasn't sure. Part of me says they should be the same since the amps RMS at that level of resistance but then I would also think less resistance on 1 sub compared to the other 2 and the one should be using more power... idk, I'm not an electrical engineer lol
11cor_k
11cor_k
marshall tx
Compjake
AJ (ACE)
    Jun 28, 2026
