3 Fi 18's VS. 4 AQ 15's???
just get another 1500, and strap each pair....then forget about the crunch 3k
if I got the hdc3's again it would have to be the newer suspension version. I feel that update was long needed
do the 4 15's and as a correction the 15's will have more surface cone area... 3 x 18 is 54 where as 15 x 4 is 60 .... thats 6 inches more. and alot more power... so it could be alot better
And run four amps on three subs? I dunno, I might just keep what I got and not keep changing every 2 months for once ha //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Actually 3 18's > 4 15's
pi x r^2
Three 18's: 3.14x81=254.34 x 3 = 763.02
Four 15's: 3.14x56.25=176.625 x 4 = 706.5 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Think it would be worth it to go from three 08 Fi BL's on three sundown 1500's to 4 AQ HDC3 15's off two crunch 3000's? Losing a little bit of cone area but gaining some more power.
Actually you're gaining more cone area and power...FYI
3 18's=54" / 4 15's=60"
3 1500 wrms= 4500 / 2 3000 wrms=6000 wrms
4 AQ HDC3 15's on 2 crunch gp 3000d pro's FTW.
3 18=54 / 4 15=60
Not how you calculate cone area...look at my previous post. But yea more power and motor force. It might not be worth the whole process of changing.
46panel
46panel
Michigan
jbizzle
