3 different subs....Different impedences?
Mynameismcgyver
Buford T. Justice
I have these questions.
-1 I have a box with 2 Rockford P1's hooked up @ 4 ohm. I have a type R 12 4ohm dvc wired @ 2ohm. Can I hook these 3 subs up (As I have wired in the pic)?
-2 Does it matter where I put my power from the amp because if its the 3rd sub in the line it gets less power, so In the middle would be the best?
my.php
Mixing different subs will cause very "muddy" sounding bass, the amp won't care if the final ohm load is alright its just that the SQ will ****.
I have these questions. -1 I have a box with 2 Rockford P1's hooked up @ 4 ohm. I have a type R 12 4ohm dvc wired @ 2ohm. Can I hook these 3 subs up (As I have wired in the pic)?
http://img34.imageshack.us/my.php?image=subwiring10hk.png
It doesn't matter where in the current flow a sub is located - the one that receives the least power will be the one that shows the most resistance to he amplifier.
Mynameismcgyver
Buford T. Justice
Mynameismcgyver
Long Island, Ny
Prowler573
