3 Channel amp? components and sub?
leastbay
I want to add a set of 6.5 inch phoenix components, and a 10 inch sub in my FJ cruiser, Im looking at the RSD65CS components and the phoenix gold rsd10, what exactly should I get? a 4 channel amp and the DVC sub ? what is the recommended amp without spending hundreds of dollars? or should I go with 2 amps?
its not too much as long as you set the gains right. but you would want a dual 2 vc for the woofer cause you'd have to wire it to 4 ohms for that amp to be stable
if its dual 4 your only options are 8 and 2 - both which are no good for that amp - well 8 would work but you'd get like no power
Probably a little much for the comps. Rated at 120.
With that kinda cash you could pick up something real nice and still have 1 year warranty.
I don't know If you are into big names like kicker but their are superior products that cost around or less than.
For 550 shipped you could pick up a sundown 1500d and a 100.2. But thats quite much for that sub.
I am just saying with 500 you got Alot of options.
leastbay
leastbay
New Orleans
leastbay
