mobster183
i ordered 3 15" eD 16kv2's subs and bx2005d amp... u think its gona be sick?...its with a ported box..
what do u mean??....sick of them? //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gifi ordered 3 15" eD 16kv2's subs and bx2005d amp... u think its gona be sick?...its with a ported box..
No sir, you need to do research before posting.only problem is that you can only wire them to 6 ohms properly... your only going to be able to get roughly 300 watts out of that amp.
unless you mean 2 ohm DVC, but still in that case the most you will get at 3 ohms would be ~700 watts.
should have done your reasearch before buying that package.
****! owned!//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif :crazy: //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gifNo sir, you need to do research before posting.
He bought 3 Dual2 ohm drivers. Meaning, he can wire to 1.33ohms(series/parallel). This means he'll be getting around 1700-1800w out of his amp, powering the 16kv2's perfectly.
What in the hell are you talking about?//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
in that case hes good to go //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifHe bought 3 Dual2 ohm drivers. Meaning, he can wire to 1.33ohms(series/parallel). This means he'll be getting around 1700-1800w out of his amp, powering the 16kv2's perfectly.
yes. i was pwn3d.****! owned!//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif :crazy: //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
hopefully he will be able to get at least 1500rms out of that amp...idk though..No sir, you need to do research before posting.
