3 12's vs 2 15's...I'm stumped.
yes they do rated power have used them but they act like a sundown and produce thair power after rise at 1 ohm i have sean a gp3000 do 3500 watts rms
i would say 2 4 inch aeros 9.5 inches long on your current box stand the box up subs up and port 2 back the box is kinda small but should keep down the rise
with my saz3500 at .6 i clamped my amps with a ported box at 2000 rms so i would dout your seeing 2400 rms
Not completely sure of this data, but it's all over the place:
Originally posted by Team Livewire - Eric:
[QB] Ok guys, here it is. Depending on your battery set up this amp will make an ungodly amount of power. With a 12volt battery set up dropping to 11.5 volts the Crunch GP3000D Pro made 2850 watts at a 1.03 ohm reactive. That's 4 12volt batteries. If you can get the voltage up the amp will make much more. By just starting the car and using the high amp alternator (starting at 16.1 volts and dropping to 12.3volts), the 3000 made 3732 watts. That's crazy isn't it. THAT'S NOTHING! I hooked it up to a 16volt battery set up and it just went crazy! With the battery voltage dropping to 15.7 volts with a 1.4 ohm reactive this monster made 4640 usable watts. NOW WHAT DO YOU THINK ABOUT THAT! [/QB]
RCobra07
RCobra07
Orlando, Fl
tangelo95
