3 12" HDC3's?
JEXTEL
well the time has come for me to get some more bass so im going to run 3 AudioQue HDC3's on 3 hk401sx's..
i did some measuring and it seems like im working with 35"W 15"H 28"D (i dont think i can get a bigger box unless i build it in the trunk, cause i still need room for batteries and amps and crap)
with those specs the box will be 6.93 cu.ft. will that be all right for 3 12" hdc3's?
next, is birch the lightest wood? because weight is becoming an iusse? and how light is it? compared to MDF
Box seems a little small, but could work..... is that 6.93 cu ft after sub and port displacement?
Yeah 6.93 cubic feet gross net probably is not enough to properly run 3 12s ported. 2 12s ported, 3 10s ported, or 1 15 ported - those are you best options for that space. The 3 10s have the most cone area, but just barely more than the 2 12s.
You could get away with 3 12s ported in that space, but each would have to have a good bit less than 2 cubes net, and an undersized port.
Mobieus used Trupan for my 8cu box.....and i can lift it by myself and put it in myself
well how is your 12's doing in 8cu? i think 6.93 will be enough..(hopefully and i already running 2 12's that why i want to set it up to 3..
well i remeasured and i think i can squeeze in 7.45cu ft box but i know this thing will weight ALOT! im balsa is as light as you say it is..
35W 15H 30D tuned to 35hz with 100sq.in. of port area
JEXTEL
JEXTEL
Bridgeton, NJ
JEXTEL
michigan born
    May 14, 2026
michigan born
    May 14, 2026
