2x Custom 15's in Ford Escape Review/ PICS
4 just sounds way to much... like for 2x18's+ but i'll check
edit: nahhh that makes em longer
if I do side firing, one of em would go right into the wheel well, but i'll see if I can pull something off.....
oooh wait... i can tune higher, and that would make em only 20" long, which leaves about 6" clearance tuned @35 which is fine..might try that. im gonna shop around a little and see if I can find some 6.5-7" tubes though
its gonna look like
O
O O though...... that ok? stupid look, but will it work
unfortunately im gonna have to tune @40hz then cause I don't have enough tube ATM for lower tuning (gettin more next week.
The reason your subs aren't hitting high excursion on low notes is because you're playing around tuning //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
When your subs are playing near tuning, thats when the ports reach maximum efficiency and your sub moves the least //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
i know, but the output is significantly less than @35-38hz
i play the radio @30/35... but when it hits the low notes, it maxes out @25/35
so basically im going to be clipping the shet outta it at full volume when it drops down low
OOOOOOOOPS!!!! self pwnt there..... TRY AGAIN!! lol!
gotta wait till the glass dries to take it back outside to cut the 3rd hole, AGAIN..
put 2 layers of fiberglass mat over it, and a bunch of bondo on the inside. if it pops out, then i'll be very impressed, and OH WELL!
whoooooooh!!!
NOW im happy!...
prolly peakin just over 40hz... still hittin the lows almost as good as it was with 2x 6" ports (makes me wonder what it would do down low @32hz w/ the 3 ports)
its at the point where i've been wanting it... hurts my ears enough to make me happy :)
snb778
blaugh!!!!
snb778
ex. Los Angeles, CA
snb778
