2X AQ220D or IA40.1?
IA 40.1 or 2x 2200ds?
  • 2x Audioque 220d
    Votes: 6 40.0%
  • IA 40.1
    Votes: 9 60.0%
  • Total voters
    15
I'd also stick with the 40.1
While the AQ's strapped may push a bit more power, it's not worth the money when you already have the 40.1 in my opinion.
i would definitely stick with the 40.1.
i dont think there is anything wrong with the aq's, but i loved my 20.1 so much i gotta lean that direction.
thats why I bought the 40.1 in the first place... I loved my 20.1
the only problem is that I have 2 3518s that are DVC 2 ohms and I can either run at 2 ohms or .5 ohms. If i got the AQs I could strap at 2 ohms
as well as with the extra current the AQs strapped would pull wouldnt give you that much more power(if any depending on your electrical system)
thats why I bought the 40.1 in the first place... I loved my 20.1 the only problem is that I have 2 3515s that are DVC 2 ohms and I can either run at 2 ohms or .5 ohms. If i got the AQs I could strap at 2 ohms
whats wrong with .5 ohms?
the 40.1 is still happy at that point //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
according to scottie johnson (take it for what you will) the 40.1 will do 44-4800 at 1 ohm. no sense in essentially switching power into a different ohm range, unless you're hoping to gain a bit of efficiency. but at 4kw+, id just put that money into more electrical instead (although, im not sure at what price youd be picking up the aq's)
cool... maybe I should do 2 ohms daily and burp at .5 with the 40.1
I would also probably just pick up the AQs factory direct cuz I just got a real job //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
cool... maybe I should do 2 ohms daily and burp at .5 with the 40.1I would also probably just pick up the AQs factory direct cuz I just got a real job //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
i ran my pr of 40.1s strapped at .8 for burps at sbn this year. awesome amps
groundpound4200
Da fuq did I just read?
groundpound4200
Mankato, MN
pawn man
michigan born
    May 14, 2026
michigan born
    May 14, 2026
