2V vs. 5V Head unit?
Here's my experience with different pre-out voltages.
Have an Excelon with 4.5v and was running a sealed Tempest that sounded very good and hit pretty hard.
Move the sub/amp into the GF's car with a 2v Pioneer HU. Reset the gains correctly with a DMM and the sub sounded like crap!!! Just hollow and empty with NO impact. Tried turning up the gain and no difference. Messed with the EQ settings for hours on end and it still sounded like crap. Gave up for a few weeks.
Then I decided to try the "forbidden" and used the loudness button on setting 2 and the sub came to life. Also made her coax's sound MUCH better. What exactly does the loudness button boost?
Any ideas on why her HU made the sub sound so bad/have such little output? The only real difference was the pre-out voltage...//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
Some HU's have built in processing. Perhaps your older hu had a built in bass boost, without even hitting a button? Again, a lower preout won't make a difference. Assumng you set your gains properly, the amp was still putting out it's RMS, it was just doing it with a lower input voltage. However, Xwatts=xwatts, regardless. Your DMM settings confirmed this. It doesn't matter what signal comes out of the hu, only what singal the amp is receiving, which in this case was still the same voltage as you had before. Loudness usually boosts the bass region and the top end, basically your tweets and sub's frequency range is boosted.
. The only real difference was the pre-out voltage...//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
//content.invisioncic.com/y282845/emoticons/idea.gif.5acb6a39a9b92425414c316dda202bad.gif
That right there is a HUGE difference. You were comparing vehicle acoustics and setup differences; not preout voltage.
Not to mention....again, you compared completely different headunits. You compared MUCH, MUCH, MUCH, MUCH more than simply the preout voltages of the headunits. Different headunits, different features/settings/etc. You were not even anywhere close to comparing the preout voltages.
Also; With just about every Pioneer headunit I've used....for whatever reason they have always sounded better with the loudness engaged. Otherwise they have always sounded exactly how you described; hollow and lifeless.
mutt_hollon
Mutt
mutt_hollon
Bowling Green, Ky
luvinthebass
BP1Fanatic
BP1Fanatic
