2V vs. 5V Head unit?
The higher the perout voltage, the less you have to turn up the gain on your amplifiers. I would prefer a preout of 5v or even 8v over 2v because I have to turn the gain on my amp past 3/4 gain just to get it to sound good (at a 4 ohm load).
And yes the gain is set properly. Checked with DMM and oscilloscope.
i prefer a higher preout voltage, as it seems to sound better. i had a 1volt sony deck, set my gains right, and it sounded good. went to a 2.2v deck, same amp, speakers, and everything, heck even same brand hu, set my gains again, and i had louder, clearer bass. others i know say the same thing. not going against theory, but you know how theory, and real life dont quite jive. in theory its like ice t said, it should not effect sound at all, but in the real world, it does make a difference.
you do know that gain doesn't effect how much power the amp produces right? //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
Completely incorrect.
But, since a higher preout voltage sounds better, I presume you have your volume maxed out every time you listen to your stereo.....because, you know, it would sound best then.
You compared completely different decks. Which means you were comparing much more than simply the preout voltage.
mutt_hollon
Mutt
mutt_hollon
Bowling Green, Ky
luvinthebass
BP1Fanatic
BP1Fanatic
