2ohm @ 1500w rms amplifier recommendations?
  • 4
I will throw in the amp I run, the Trauma 2000.1, built like a tank, Korean made and will produce 1500 at 2 ohms. You also have the Taramps Smart3 and bass 3k, both will do what you need as well. Pop has been talking about Ruthless audio as well, I believe they are also a Korean type amp.
After purchasing my 2nd sub, I see I do not have the power I thought I had. looking to run 2 15" 750w rms subs at 2ohms
No shame at running at 2 ohm mono. I have a pair of heavy tens in 4.0 @32 HTZ that was on a Matts D300HC that was flexing my roof to almost a crease in my older 99 CCRV with an old Crossfire TEK 100.2 and a Concord 50.2, with 2 agm batteries, Big 3 with ELD Bypass on a stock 90 amp alt. Joker got down
All dammned good options on amps mentioned. Id throw in the CT Sounds 3200.1. Im enjoying the 2k and the 150.4 so far. There are some Dyno test of both amps on You Tube. All theyre amps can be strapped as well. Excellent Customer service and support from Kurt there.
brice15s
CarAudio.com Recruit
brice15s
Virginia
brice15s
Brendon Jenness
    May 8, 2024
    May 8, 2024
