280 pound package arrives today
Update
http://www.caraudioforum.com/vbb3/showthread.php?p=1849117#post1849117
To add, the dual Crest is to run bridge mode for 10kw - 15kw per woofer array.
There is two tower woofer arrays planned with four 15" Lambda TD Apollo
woofers. These are not subs, the woofer array is not a sub array, it's a wideband
woofer with 16mm xmax, great SQ... The woofers can do some sub duty if
you port the box. In my case, I'm thinking 32hz - 35hz to keep cabinet size
reasonable. I want alot of chest pounding bass, not 15hz rumble. The bridged
Crest has ~320V of clipping headroom {not factoring in losses}.. I should get
incredible slam with the amp.
... so in other words, I don't have a HT sub in my plans yet, dunno if there is
room for one and I'm unsure if I really need one... I'm not too picky about
having super LF in the house. Lets see what monster woofer AE comes out
next year, rumors about a massive motor 18" in the works {shhhh}...
Maybe I can fit one in the room if the box isn't too big... Maybe behind the
line array towers? /unsure... Behind the line array is a fireplace that will be unused,
maybe make a subwoofer box and shoove it in there - hehehehe
dang... do you use like a 220V outlet for those...christ almighty!
poor poor neighbor kids at halloween next year will be in the hospital instead of just having soiled pants...lol
The amp can be rewired for 120 or 240 {and other options}, but the amp is
so cramped that I couldn't figure out which wires were which.. I may just leave
it as is..
Some other 'boner' amplifiers that look sweet.
Accuphase M-8000
http://www.accuphase.com/pdf/m-8000_e.pdf
The Crest has 14 parallel transistors per rail for output stage drive and is
a stereo amp. This Accuphase has 12 parallel transistors but is a monoblock
design. There is no reason why it couldn't be a stereo amp, they just want
you to buy two of them. Crest heatsinking is superior with the wind tunnel
heatsink. Accuphase wins on eye candy. /lol/
I paid $2k for Crest {used}, MSRP for M-8000 is $20k each, $40k for stereo mode. /harr harr...
Pass Labs X1000 {discontinued} is nice if you think class A buys you SQ,
but it really buys you a heater.
http://www.passlabs.com/amplifiers/x1000.htm
1000w @ 8 ohm monoblock. 200 pounds. Excellent build quality and product,
high voltage rails. $12k each. 1% THD @ full power.
If you think you need 'parts per billion' distortion figures, then snag a Halcro.
DM88 is $20k for a monoblock, $40k for stereo. Low power ratings. /boo
http://www.halcro.com/productsDM88.asp
Proamps are the best kept secret in home audio. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Two Crest; ~$2k ea. used.
Ten QSC PLX3402; avg. $765 ea. used.
Crest = 15KW
PLX3402 = 3.4KW
Crest =13.3 cents per watt rating.
PLX = 22.5 cents per watt rating.
A pair {stereo mode} of those Accuphase amps brand new is $10 per watt.
Lets say you get them used 1/2 price, $5 per watt. /hehe
not to burst your bubble, but at 120volts and just 5000 watts your looking at a 41amp draw. most homes have 15amp or 20amp breakers for each room, I'd plan on hiring an electrictian. Unless someone please correct me if I'm wrong.
Look at past threads, he's documented past electrical upgrades //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif...
NG
The amp has one AC cord per channel, two 120VAC 30A plug. You can also
wire it for 240VAC if you wish. For now it has this.
http://www.kennedypower.com/catalog/images/products/Accessories/L5-30P.jpg
Homes don't have these receptables. I'm installing a dedicated electrical subpanel,
three 2 awg cables and one 4 awg for safety ground already installed under
the house.
/think big
thylantyr
thylantyr
[Yoda] Belong to us all your base are...
monte_carlo97
