i have a 275g4 orion amp and 2 12" xtr pro dual 4 ohm voice coil subs. i have them wired parallel to the amp bridged to see a 1ohm load. amp is rated at 1200x1 at 1ohm. but it just dosent seem to be putting out that power. it dosent seem to be pulling as much current as possible either. i have 10 gauge power and ground to the amp.i know i need bigger but i didnt think it would matter for testing purposes?? and i got a volt meter on the amp and when the bass hits its between 8 and 9 volts at the amp. is this normal. what is the problem???? help
