2500D question.. need answer
are u sure you checked the settings on your headunit?
I did a direct amp swap. No settings was changed from the Memphis 1000D to the 2500D.
But, yes I did check. All in order.
I put the Memphis in.. its working fine. So I reinstalled the 2500D. Making sure every wire was going exactly in the right place, double-tripled checked everything. Still not working.
Than u got f**ked up amp dude!Nah just playin,I see that u hooked up on one power and ground which makes me believe that u most likey "bridged"the amp,well if so just use one set of the termanals,the amp is bridged interally.
I am the guy that sold the 2500d. I received the amp back yesterday and hooked it up today. I works fine. I think it had to of been an incorrect filter setting. Just wanted to let everyone know that the amp is working fine so no one thinks I sent out a faulty amp.
Digital B
Here Comes The Boom
Digital B
NC
B_Campbell
AJ (ACE)
    Jun 28, 2026
