250 amp GM alternator
  • 4
nutxo
tacoma
Item(s) for Sale: 250 amp dual rectifier GM alternator. Its currently installed in a 95 camaro with an lt1 . cs144 large case. You'll have to check and see if this matches your application. I wont be responsible if it is incompatible with whatever you are trying to install it on.
Item(s) Description/Condition: Ive been using it for a few moths and have had 0 issues with it. I'm going smaller though and wont need it anymore. Its just like this but the fan is different. The fan make zero difference according to my local alternator guy though. I drilled out the threads on the top of the bracket to worth with my stock brackets. On the back bracket I need to grind off a bit to keep it from touching the external rectifier.
CS144 Series 250 Amp Extreme Duty Dual Rectifier Alternator
Price: 200 plus shipping and handling
Shipping and Miscellaneous Item Information: If itll fit it will go in a usps flate rate box. paypal only, no echecks.
SO we dont know if it fits my 1997 cadillac with the 4.6 liter northstar engine??
got a pic? I just looke dit up. It seems to be a cs144 if the clock is different you might need to take it in to have it reclocked. My local guy charges 10 bucks for that. Im 90% sure the brackets are right but I dotn know if the extra rectifier will have room on your engine.
more info from the person I got it from.
" Output is 250a+ @ 1200 engine rpm, "universal" wiring with a GM CS144 large case. I have adapted these to SEVERAL vehicles with ease!! it is an "extreme duty" dual rectifier alternator. Includes two heavy duty bridge rectifiers and a standard 14.7V set point voltage regulator. List price on these is $429.95 on their website.
It is a direct replacement for the fallowing alts: 7802, 7861, 7864, 7894, 7901, 7918, 7921, 7977, 8103, 8112, 8160, 8163, 8165, 8172, 8173, 8203, 8206, 8216, 8219, 8221, 8227, 8231"
bump
I have heard you can swap them with a bracket. I am not sure if this is true, but I am very interested if it can be done.
I dunno man. Check it out. I dotn wanan be the guy that says yeah and then it not work. The alt is nearly new though as I hardly drive the car so its a screamin deal at this price.
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
338
I was going to run those same Jbl's before I went insane about the car. Glad I would've made a good choice.
  • Locked
THESE ITEMS WILL BE REMOVED FROM THIS FOR SALE THREAD ON AUG,16.2022 @9PM CT THANKS
93
nutxo
nutxo
tacoma
chargdbassbuick
    May 16, 2024
    May 16, 2024
