Item(s) for Sale: 250 amp dual rectifier GM alternator. Its currently installed in a 95 camaro with an lt1 . cs144 large case. You'll have to check and see if this matches your application. I wont be responsible if it is incompatible with whatever you are trying to install it on.
Item(s) Description/Condition: Ive been using it for a few moths and have had 0 issues with it. I'm going smaller though and wont need it anymore. Its just like this but the fan is different. The fan make zero difference according to my local alternator guy though. I drilled out the threads on the top of the bracket to worth with my stock brackets. On the back bracket I need to grind off a bit to keep it from touching the external rectifier.
CS144 Series 250 Amp Extreme Duty Dual Rectifier Alternator
Price: 200 plus shipping and handling
Shipping and Miscellaneous Item Information: If itll fit it will go in a usps flate rate box. paypal only, no echecks.
