220amp alt, whats my limit ?
BassAddictJ
ok....when everythings said and done (bought and installed i mean) i should be running :
220amp iraggi alt
2 red tops
dual 4 gauge wire
dual 4 gauge for the big 3
the car is a 2002 vw golf hatchback, so the power wire goes about 16 feet before it reaches the 2nd red top in the trunk area....
roughly how many watts rms can i run daily before i get voltage drop from overpowering the electrical system (in a perfect world assuming nothign else goes wrong and causes voltage drop)???
220amp iraggi alt
2 red tops
dual 4 gauge wire
watts = amps*volts. Your alernator probably puts out ~14volts, so figure you have 14*220watts on tap at any point, from your alternator. Figure 40a or so for the car's electrical system and you end with 14*180 or so or 2520watts before you have maxed out your alternator and are pulling off of your batteries without charging them. You may or may not see voltage drop at that point, but you will certainly start to see it if you try >2500w for extended periods of times. On the plus side, it'd be pretty difficult to pull 2500w CONSTANTLY so you will probably be dynamically pulling way less than that rms. Don't bother with another red top unless you find that you are draining your existing batteries to the point that it becomes problematic.
More batts is always a good idea with a nice alternator. My kinetik I threw inthe back helps a LOT, i mean A LOT. I can actually use my heater now in the morning with more voltage, lol.
i wish i got he yelow top since it's eep cycle...at the time i could afford it so i went wiht the red top, then i managed to get another red top for 40 bucks direct fro a battery plant my friends dad worked at (interstate batteries, FL).... i know if you mix batteries without a celinoid or battery isolator they need to be the same kind and perferably the same age(in terms of time useage). because they will pull energy off each other when the car is truned off...and thats bad...
i think ill be fine with the 2 red tops...worst comes to wrost ill get a yellowtop for the hood and keep 2 red tops in the back......but i dont expect to be pulling more than 2500ish watts for daily, none the less music....
BassAddictJ
BassAddictJ
FL
BassAddictJ
michigan born
    May 14, 2026
michigan born
    May 14, 2026
