210 Mph!!!
If this game is the same as 2 years ago, then it is easy to cheat.
EDIT: ya same one. Easy to cheat, but for some odd reason I can only do 550 on this computer at work, but have hit over 700 at home.
theres a guy in orlando with a busa, pegged the dyno they have and it reads up to 700 horses. i guess they have a speed setup on there as well, and he maxed at 275, but this was on a dyno....and the bike had much more work than anyone would ever wanton a street bike....none the less, it looked stock.
From all the stuff I have been reading and watching the main video posted here is the fastest busa out at 499cc. And I have been doing alot of reading and sht my buddy is a freak on watching videos etc and sending me all the good ones and info its like his life. And he even told me that this one is the fastest on the net right now.
Ok, you all realize that speedos... like ALL of them are over rated right? esp on motorcycles.
and by far the best motorcycle videos are the ghostrider DVD's. That guy's effin insane.
X2
Check out the Getaway series. Same locations as the original Ghost Rider just done in cars.
That video's atleast a year old FYI, and if memory serves me correctly I beleive it's just a turbo busa that is only doing 12 psi or something, instead of the 20 something max they can take.
Personally I'd MUCH rather have a turbo GSX-R1000... turning = good
speedometers aren't underrated, and modding the engine and drivetrain wont affect the speedo reading, unless you swap in a transmission with different gear ratios. i'm not sure what its called on a bike, but the rear axle gear, swapping it would affect the top speed, acceleration and speedo reading. my car's speedo is still set up for either 3.23 or 3.42 gears and i have 3.73's, so at 70 on the interstate it says about 95.
Ever used GPS on a bike? //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif They are over rated. As is my stock Caprice.
Oh my lord.. undereducated children. A speedo is a speedo. Don't trust GPS, trust a cop who's also a biker and brings out the radar to a session to meter everyone. And no, it is ENTIRELY possible to go faster than your speedometer can read. Speed is based on engine rpm and gear ratio.
You can do all the engine work in the world, but if you leave your transmission alone and use the same gear ratio's, the only thing you achieve is hitting your redline in top gear faster (and if you don't use wider gears, then you aren't going any faster than normal).
Engine work + stock gearing = fast acceleration.
Engine work + wide gearing = ok acceleration, higher top speed.
Engine work + short gearing = massive acceleration, lower top speed.
And those axle gears are called sprockets, you increase the number of teeth on the rear sprocket to give yourself shorter gearing (faster acceleration--better wheelies), or decrease the number of teeth on the front (engine) sprocket for the same effect.
your right, it may be on the NET......but this one is right down the road from my old house. hell go see the place when u move to orlando.....wasnt that u moving there?
orphe
orphe
Houston
75MonteCarlo
vegang
vegang
