21 " incriminator audio dp's
cal
I.A. DP'S
2. S• 8 Spoke Black Cast Basket
• 3" Heavy Gauge 4 Layer Flat Aluminum Voice Coil
• Triple Black Progressive Spiders with Woven Tinsels
• High Pressure Kraft Fiber Reinforced Cone
• Multi-Layer Foam Surround
• Double Stacked Wedge Magnets with Black Nickel Finished Top and Bottom Plates
• Interlocking Aluminum Spider Spacer Assembly
• CILD - Center Interlocking Dustcap
• ADC - Air Driven Cooling - Six Column Vents for Max Motor Cooling
• S.T.A.R. Motor Design for Built in Motor Cooling
• Nickel Plated Push Terminals
• Wrap Around Rubber Gasket (not available for 21 " subs)
• 1500 watt RMS Rated
• DVC 2 ohm
new as in never used or mounted . these are not recones . they have some light scratches on the motors . these are dual 2 ohm but read closer to 1.5 per coil. these are stiff like morning wood:blush:
these came from an authorized dealer so no b.s. i got them with the tiny blemish on the motors and did not bother me but i posted it just to be straight .
only reason im selling is because i need my trunk lol
950 picked up
1100.00 shipped con u.s.
What do u think these can really handle?
in the proper enclosure according to IA audio 2500-3k clean unclipped power per driver daily . the motor is designed to cool and the coil has some upgrade from the previous dp motor . these were made to handle a 20.1 amp per driver easy
thanks cal
cal
cal
cal
