2014 charger 4 channel amp issues
mxjuxior
texas
I have a 2014 charger that had a beats audio system I bypassed the amp using crutchfields amp bypass harness ram it to a lc7i then to the amp I’m getting a bad static at full volume no music or even at the lowest volume not as bad I’ve been trying to fix it for weeks with no luck I tried my grounds ground loop isolators rewire and wired straight to the amp with no luck anyone have any ideas on what I can do
I don’t use it often, mostly bc I’m deaf to it. I hear the literal word combination and am unable to decipher it although, it seemed appropriate here.
Have you considered an aftermarket amp. When I did the amp bypass harness, I avoided the factory amp. No issues for me. Your issue may be related to the output level on your lc7i and the factory gain level on your factory amp. Just a guess. I would contact Crutchfield. Good luck.
Yes I have aftermarket amps stock amplifier is bypassed but I’m getting a new amp and a new lc7i no matter what I do nothing helps
Do you have about $100 to waste? Try a cheap amp that has line-level inputs, see if that helps. WalMart carries a 4 Channel Jensen amp, for its price, it's worth a shot. If your replacement speakers dont need a ton of power, this amp could be the end game winning ticket. Im NOT promoting it, nor saying its the greatest, but I've heard it in a charger with the stock alpine system with upgraded alpine aftermarket speakers, and someone gave him the Jensen 4 channel, and it was nuts, I was shocked it was a Jensen amp.
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
Another option is to get the 4 channel amplifier and purchase 2 surface mount speakers for the rear deck and 2 for the front kick panels. Running...
983
I just ordered a Sony XM-GS4 amp for the Focal door speakers. The Mosconi Pico 2 powers the factory subwoofer, and sail panel tweeters. I'll post...
683
id put in a good new deck and front speakers, forget the rears (fade to the front). then when you get a new car, take the deck and front speakers...
989
Kicker 46CSS654 CS Series 6-1/2" component speaker system chose these for the front chanel Kicker 46CSC654 CS Series 6-1/2" 2-way car speakers...
mxjuxior
mxjuxior
texas
SilverSquared
slater
    May 2, 2024
slater
    May 2, 2024
