200A Alt GM/Saturn FS
blackdragonx118
No bearing noise or anything. And no, I don't know what else this will fit. You have Google just as much as I do.
Up for sale is a 200A alt I bought from Tenney about a year back. I didn't drive my car enough to really need this sadly as I lived so close to work there was no time to bump. As you can see there is a broken fan blade, so it does have a vibration, but I did not see anything or issues while the engine was running. The honest reason I stopped using it was due to the pulley size, I was not able to get a belt the right length to avoid it slipping under heavy loads, although with a new belt, it didn't slip, and my voltage was solid. It does have a different connector than what my car used so he made a ghetto, but very effective harness for it. If you take the fan off, you will have zero issues with it, but as of now, I don't have time, (or sadly a running car) to use this on, so my loss is your gain.
see above, used
$125 obo plus shipping
I'm going to check to see if it will fit a 2.4 motor on my winter ride if it can be rigged on than i may take this off your hands. i'll let you know.
blackdragonx118
blackdragonx118
North Las Vegas, NV
blackdragonx118
