Hey im getting 2 Fi BTL Subwoofer and a HIFONICS XXV Goliath for my 2008 Jeep Wrangler Unlimited. I will be setting it up with a 4.861cf^3 ported enclosure tuned at 32hz, a performance optima BAT. and 1/0 Gauge Wiring to the amp. The cyclops puts out 5000x1watts @ 1 ohm and the BTLs are rated at 2000rms. The BTLs will be setup up with every option, except universal. It will be the daily version, with cooling, third slug and high x max coil. Will I be needing to do the BIG 3 seeing that the standard alternator for the 2008 wrangler unlimited is 140 amps? so I will not be needing to change the wires to and from the alty if there already is 1/0 gauge wiring.
Also do you think that each sub will be able to take 2500 watts each? How much can they take with all the features I have added on?
