2006 buick rendevue
12volts
orange (20A), orange (10A)
ignition harness
Starter yellow + ignition harness
Second Starter N/A
Ignition pink + ignition harness
Second Ignition dk. green + ignition harness
Third Ignition N/A
Accessory orange + ignition harness
Second Accessory brown + ignition harness
Keysense lt. green - ign harn or BCM, gry 16P plg, pin A5
Power Lock red/black - dr kick or BCM, pink plug, pin B4
Power Unlock same as power lock wire
Lock Motor gray 5wi DKP or fuse block, blk plug, pin B2
Unlock Motor tan 5wi DKP or fuse block, blk plug, pin A1
Parking Lights+ DO NOT USE
Parking Lights- lt. blue - sw or BCM, gray 16 pin plug, pin A6
Hazards tan - switch or fuse block, gry plg,pin E2
Turn Signal(L) lt. blue/white + switch or fuse block, gry plg,pin F2
Turn Signal® dk. blue/white + switch or fuse block, gry plg,pin F1
Reverse Light lt. green + fuse block, black plug, pin C10
Door Trigger dk. blue/white - BCM, pink plug, pin A3
Dome Supervision gray/black - fuse block, black plug, pin C9
Trunk/Hatch Pin pink/black - BCM, pink plug, pin A9
Hood Pin N/A
Trunk/Hatch Release white/black - BCM, gray 16 pin plug, pin B1
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm purple - dr kick or BCM, pink plug, pin A4
Disarm No Unlock see factory alarm disarm
Tachometer NOT pink or white ac any fuel injector
Wait to start N/A
Brake Wire white + brake pedal switch
Parking Brake orange/black - switch or BCM, pink plug, pin A1
Horn Trigger black - sw or BCM, gray 24 pin plug, pin A11
Memory Seat 1 white - mem mod under seat, gry plug, pin A3
Memory Seat 2 purple - mem mod under seat, gry plug, pin A2
Memory Seat 3 N/A -
Stroker_Boy
Kendall
Stroker_Boy
Adrian, Mi
Stroker_Boy
