2005 Honda Accord Upgrade
SIIMONSEZZ
NY
I Have A 2005 Honda Accord, I Do Not Want To Change My Head Unit. I Would Like To Install An Equalizer, Amp, Subwoofer And 4 Replacement Speakers. Can This Work And What Is The Best Way To Install. I Am Not Interested In Extreme Loud Sound But Clear Loud Music.
first- turn off capslock.
use a 4channel amp for four non-bestbuy coaxial speakers. look at http://www.thezeb.com and http://www.sounddomain.com for some good deals. us acoustics makes some good amps. profile is a little cheaper in both quality and price than other brands, but they put out near their rated power, and the work perfectly fine. most of them come with another piece of hardware-
a line output converter- aka- LOC.
this will steal the signal from your rear speakers, and use it to send music to your amplifier so you dont have to replace your headunit.
maybe get a RE RE 12" subwoofer, or a pair of RE8's and make some sealed boxes for them. you dont need an EQ- period. as long as you set your amplifiers correctly, and you dont crank the volume with max bass and treble, you should be fine.
check ebay for everything, sometimes you can find some awesome deals.
Thanks for the quick reply, unfortunately i already have a EQ, my next question is would the control of the sound be better with a EQ, if the EQ will not improve the sound i might has well sell it.
thanx
SIIMONSEZZ
SIIMONSEZZ
NY
JL_W6_v1
