2004 stratus big 3?
Xjeff
Ok so I was doing the big 3 on a buddies 2004 dodge stratus and I noticed the stock wires only has the batt + to alt + and then batt - to frame. But no batt - to engine block, there's a wire from the frame that the batt - connects to that leads to the engine block. So should I just add the big 3 wire from the frame to the block, or run the big 3 from batt - to the same block ground? Well for now we did a big 2 upgrade lol, but plan in doing something tomorrow with it, cus it still didn't fix the lights dimming.
Most alternators don't have a negative... The case itself is the ground for the alternator and it is ground through the engine block which usually has a tiny wire run to a chassis ground. Do a run of wire between a chassis ground and the engine block or the alternator case, either will work.
Xjeff
Xjeff
The dalles
Tenacious
