2004 12" RE XXX Subwoofer - $500 - LaPlace, Louisiana - LOCAL PICKUP
Disarm99
2nd generation (cant remember exactly when i bought it, sometime between 2003-2005 directly from RE)
12" RE XXX Sub
Never mounted, never seen power. Only stared at and moved back and forth.
Light scratches and surface rust on bottom of motor that i removed with a fine grit sand paper.
I will not ship since I don't have the wooden box anymore and I have no confidence in being able to pack this beast of a sub for secure and safe shipping.
I am in La Place, Louisiana and would be willing to travel up to 100 miles to meet you as necessary.
Sub sold as-is, but as i said, it has never seen power or been mounted.
First $500 takes it.
Contact me by PM.
Yes, an IOTA DLS-75 AC to DC power supply converter. I plan on using as part of a test bench for DC electronics and an emergency battery charger. Pretty nifty gadget. It will allegedly output a continuous 75 amps at 13.4 volts or over 1000 watts of power. Ill let it go for $225. It is UL certified so you will need a UL certified wall socket to plug into (the sideways plug) which needs a 20 amp circuit from your breaker box to the outlet if I remember right (dont quote me on that). I'm in no hurry to sell this though since i can always use it.
I have motivation to see the sub find a new home though because I drive a small truck and dont have the space to use this beast, even in a small sealed box. Otherwise it wouldn't be for sale, i assure you.
you guys win, $300 come and get it. Im in LaPlace, Lousiana and can meet up to 30-40 miles aay. I would ship except i dont have the box and theres no way i can build a crate to secure this thing to ship.
300 bucks for a mint xxx like that is a hell of a deal. someone pick this up! if only i had the extra cash...
xbl^2 yummy goodness...//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
So flat can be synonymous with bright? I assumed otherwise…shows my level of understanding. Speaking of mixing or mastering, the way it’s setup...
42
4K
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
De radio van mijn seat Ibiza uit 2004 losgehad. En ny staat die op save mode en kan ik helemaal niks meer😬😬. Iemand een idee dit weer aan de...
Just need to check out the old one. no radio sound. but pops when turned on and off . Fuses look good
I have a set up but am looking to hide my amps, I have a 2004 sequoia. Does anyone have a set up like this or pics of an installation?
Disarm99
Disarm99
Orlando, FL
Disarm99
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
