2001 Honda Civic Alternator Question
That is the ELD saving you gas mileage. nothing is wrong, everything is working as-is. the ELD doesn't turn off the alt unless the vehicle is in gear.
Lighting isn't through the ignition, since you can have lighting while the car is turned off. the ELD only monitors the load on the ELD that is ignition based (and fed through the ELD).
Turn your A/C on or defrost on, etc. and the voltage will increase. But this isn't a solution since it robs the alt of current for those devices.
The ELD bypass I developed works great.
http://forum.sounddomain.com/ubbthreads.php?ubb=showflat&Number=1804618&page=1#Post1804618
you have pm need help please
Yeah bro unfortunately most USDM Honda have this setup from factory my car which is a JDM accord has it too took a while before I found a forum with the issue explained and no one was able to help me locally they all said it was wiring and maybe alt wasn't charging properly and crap but i found a write up on sounddomain //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif!! Until i start messing with the wiring I just keep my headlights on or run the a/c in the day.
Drummer65
Drummer65
Newport Beach, CA
crucial24
