2001 F150 Lariat Pioneer 80prs to factory amp issues! HELP!!!
Bostonjlguy
I installed an 80prs in my f150. I get only highs like a tweeter from the rear doors and only the right speaker works in the front doors. All 4 speakers work fine with the factory deck. I am positive it has to do with the factory amp. I have had to hook up a different remote in jeeps with factory radios. I cannot find out which wire is the remote in the f150. The factory deck uses two clips and the after market only uses 1. Hoping someone has experience with the same vehicle.
BestKits
here you go if you want the factory sub if there is one. if not then you probably have another problem. And if i had to bet I would say you have another problem. the fact that one of the front speakers works means that the fact amp isnt running the speakers, just the sub. (if there is one) I would double check the wire harness and make sure one of the pins didnt go astray on you. As for the rear speakers only putting out highs I might say you have the settings on your deck out of whack.
appriecate it man! I was so busy thinking about it that I didn't even think I could look it up with a multimeter.
You should use an adapter. You might gain some insight on a Town Car forum as well. https://www.installer.com/cars/by_car.php?carid=3402
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
Thanks so much guys. Talked to crutchfield support with the same question and although they likely don't know everything, and sometimes, salesmen...
They really are. Fit to perfection! Sounds Good Stereo are the best.
Bostonjlguy
Bostonjlguy
Dubuque, IA
CrossoverOre
    May 18, 2024
    May 18, 2024
