badstang123
I have a 2009 Avalanche with the system in sig. The system will do about 1500 watts rms and when I crank it up and the subs hit , it will cause headlight dimming. What I intend to do in this thread is show each small step I take until it is eliminated, so that others will have a useful guide on what upgrades help the most and how far they have to go in order to alleviate voltage drop off and dimming lights.
Don't forget that during this process I will also be combating the variable output alternator that lowers voltage output to 12.7 volts when the battery is fully charged. I also intend to take my modifications to the extent where I have the stock alternator putting out at least 14.4 volts at all times.
The starting point. My system has a 0 gauge lead from the positive battery terminal with a 250 amp ANL fuse. The run of 0 gauge leads to a distribution block within a few inches of the amps and a set of 4 gauge power and ground wires for each individual amp.
Upgrade 1 - The Big 3:
Alternator wire to fusible link upgraded to 0 gauge
I left the factory fusible link intact and upgraded the wire from battery side of fusible link to the battery to 0 gauge as well. The starter wire was also moved from battery terminal to battery side of fusible link due to available wiring inputs on battery terminals.
The negative battery terminal to chassis ground was upgraded to 0 gauge and relocated to top of the shock mount which is part of the main chassis
I still have to do the block to chassis upgraded to 0 gauge but no one local had anymore 0 gauge ring terminals. This mounting point on the block is within 6 inches of where the other ground on the shock terminal is, so I will connect it at the same point when I have the needed terminals
I still have some cleaning up to do and shortening of a few wires but here is the end result so far.
Lucky Bonus!!!!
The factory system for monitoring the battery's full charge and reducing output to 12.7 volts when fully charged is monitored via the following ring and electrical connector which the stock ground wires run through:
I don't know if the additional separate 0 gauge chassis ground (Obviously outside this ring) is now the path of least resistance and is affecting the PCM's way of monitoring whether the battery is fully charged through that loop, but since I installed the new negative battery terminal to chassis ground in 0 gauge, the net result is that the system always maintains over 14 volts. I thought I would need to buy Missing Link Audio's unit but so far so good without it. I will keep an eye on it over the next week and keep you all updated.
Despite The Big Three, on bass hits at high volumes, the headlights still dim. My next step will be the block to chassis ground in 0 gauge (Which I do not think will make little difference given that it's already 4 gauge) and then I will probably put a good battery up front since there is no room for one in the rear (I would like recommendations on this). Any input or suggestions are appreciated and I will keep you all updated on my progress so others with 2007 and up Chevy Trucks and SUV's know what works best when doing electrical upgrades.
Best Regards
- Justin -
Lucky Bonus!!!!
Best Regards
- Justin -
