Lots of head room? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifNot going to do any good with 180 amperes of current draw from the sub amp, 20 amperes of current draw from the speaker amplifier, and not to mention the rest of his car ...
Sorry, but more batteries is not going to make up for the alternator only being able to supply 1/3 the required current ...
If he limits the power output to about 900 watts on the sub amp, then he'd be fine ...
But then what's the point of buying an 1800 watt amplifier ?
i suggested that because I know a guy on Sounddomain his name is Vitveet and he has a stock 80 amp alt on his civic and has 2 ed Nine.1 amps strapped and also an amp for his comps.....all he has is a yellowtop under hood and yellowtop in the trunk with ALL 1/0 gauge wiring, and big 3.....just minimal dimmage hes been using that like that for 2 years.....Not going to do any good with 180 amperes of current draw from the sub amp, 20 amperes of current draw from the speaker amplifier, and not to mention the rest of his car ...
If he limits the power output to about 900 watts on the sub amp, then he'd be fine ... But then what's the point of buying an 1800 watt amplifier ?
no need for a second battery unless you do "parking lot" listening period! if you listen to power hungry music than a high output alternator would be the way to go. but before you do that install your system and then decide if you need it. to determine if you need it find someone who has a high output alternator and using jumper cables hook their electrical system up to yours. their engine should be running but leave yours off. turn on your headlights and audio system. if their ho alternator makes a difference go ahead and buy one.
