2000 chevy firewall
The Lion 817
I need to run my wires for my amp kit in a 2000 chevy x-cab truck. i have 1 4 ga. wire and a few 10 ga. wires (pa/cb system) and i would like to run them all through the firewall, i'm tired of the roadnoise coming in from the doors. please send some kind of diagram if you can find it or just very detailed descriptions. thanks.
-phil
if it's an automatic... get down and look from the inside... where the clutch would be... see if you see a spot where there is a metal plate or a rubber grommet that you can poke through there... if not... look up and to the right of the gas pedal and there is a rubber circle that is part of the mat that covers the firewall... pull the circle off and there is a perfect spot to drill through... you can access it easily from the outside and the inside...
The Lion 817
The Lion 817
Fort Worth, TX
Norcalracer283
michigan born
    May 14, 2026
michigan born
    May 14, 2026
