2000 Blazer Help
connersdad19
The wife and i just got a 2000 blazer 4d 4wheel drive and i am looking at putting a system in. The only downside is, is that i still have to have room in the back. Would i be able to do an 18 inch sub? or would it be best to do a single 15. The sub i had in mind was a aq hdc3. I know its a generic question but thanks.
i have an 18 in a 99 blazer, and i have 0 trunk space left. i dont even think a 15 will leave you all that much room. i just use the back seats as a trunk, and when i need the trunk i just take the sub out.
My brother used to have a 99 blazer and even w/ a single 15 ported he had very little room left afterwards. Box was 4.5ft3, below the window line and left little room.
With a single 12 you could pull it off though, something like an RE SX w/ 1k daily would be nice.
length is 38.5 height would like to be around 17-18 and width would like to be around 21-22 or shorter if possible.
would 4 tens work if they were staggered? or should i just do 4 8s across? or one 12 or 1 15?
good point.
i wouldnt need it on the sides just a little up front....but perfecxionX had a good point that i could just use the back seats so now its just about money. i would like to go with some tens as i have never had em before so either 4 cheaper tens or those two orions....but max is about 450-500
i was thinking them subs on this amp
http://www.sonicelectronix.com/item_7562_Orion+HCCA-D5000.html
2 10 hdc3s will be around the same price.
connersdad19
connersdad19
Logan, Ohio (43138)
connersdad19
vegang
vegang
