200 rms x 1 @ 1 ohm stable
what sub or subs are you running?
2x Rockford Fosgate P112S4 but if i can find a good cheap amp stable at 1 ohm then i will get another P112S4 and wire them in parallel for a 1.3333 ohm load, so i was looking for a nice amp to compliment their rated 200 watt rms wattage
Most amps that are 1-ohm stable put out at least 600w. Why not just stick with the two you have and find an amp that puts out the correct power @ 2 ohms?
The main reason why i want to get a 1 ohm stable amp is so i can get another sub, right now i have a rockford 500bd powering 2 12's at 500 watts rms but i have the gain set to almost 0 so its not exactly 500 watts, i wanted to get another amp so i can get another sub and have more bass with the box im going to build. I wanted to know if anyone knew where i can get the amp from and how much it will costs, since im going to build a new box some time this week, that way i can build one box for 3 12's instead of 2 boxes, 1 for 2 12's and when i get the third sub a single box for the 12. TIA for all help.
Decipha
www.EFI Dyno Tuning.com
Decipha
New Orleans, LA
Decipha
