200 dollars. 12 inch. 1,100 RMS. Can it be done?
Roasted
So far the closest I've gotten is the SX 12, which is 249 bucks.
I'm up for going with a single sub, or two, as long as they can handle 1 ohm/1,100 RMS. I prefer sealed, but MAY port down the line. I'd like 12 inch subs, because my SE 15 barely fits where it's at now... it's hard to make a nice box due to the wierd rear deck and how low it is.
How would the SX12 with 1,100 RMS sound versus the SE15 with 600 RMS? I want to make sure that downgrading sub size, but upgrading the sub itself, won't lose overall output from what I currently have. I also want it to justify the price. Meaning, I don't want to spend 250 bucks on a sub that gets me .002% louder.
Looking for a set of 12s too if a single 12 doesn't work out. Any possibilities? Open to anything.
How about this, with what you just read, what would you buy with a price cap of:
200 dollars?
250 dollars?
300 dollars?
i heard the power acoustic fubar is crazy and cheap
i wouldn't give the type r are that much power in a sealed though,
due to increase power handling of a vented enclosure
Pioneer TS-W3004SPL - Got mine for $134 shipped, should be here tomorrow.
http://www.pioneerelectronics.com/pna/product/detail/0,,2076_4061_153020681,00.html
12"
Voice Coil
Dual 4-Layer, Long Voice Coil
Voice Coil Wire
Ceramic-Coated
Specifications
Watts MAX. Music Power 3000 Watts
Watts Nominal Power Handling 1000 Watts
Frequency Response 18Hz ~ 700Hz
Sensitivity 89dB
Ohm Rating DVC (Dual 4 Ohm Coils)
Recommended Enclosure 0.85 ~ 1.75 Cubic Feet
Dimensions 13" x 8.1" (329 x 205mm)
Mounting Depth 7.3" (185mm)
Roasted
Roasted
theCybe
