2 x Atomic APX 12's 856, NEW
72Impala
2 x Brand New Atomic APX 12's. 856. New motor style.
2. Specs:
D2
Probably handle 4000-5000 daily in right application. Atomic says 15k burps.
These have the spiders glued, AND screwed down.
EXTREME SPL competition woofer
* High sensitivity, extreme efficient motor to ensure high SPL possible
* Rigid Die cast aluminum basket
* Organic long fiber non-pressed cone body for accurate tight bass
* Highly damped Kevlar and carbon fiber reinforced cone body
* Triple layers foam surround increase the power capacity of woofer
* Extended neck joints on cone, coil and spider strengthen the integrity of moving structure for high power capacity
* Compressed mounting ring gasket
* Over sized lead wire stitched on the spider, conduct signal current with ease, minimum loss * Vented coil for extra heat dissipation
* 3 inch high temp aluminum voice coil
* Extended, machined cut one piece back plate
* Powerful double stacked high and wide energy magnet
* Over 2-1/2 inch long excursion motor structure
* Reinforced resin impregnated polycotton spider extend the life span of the speaker from material fatigue and collapse.
* Integrated heavy duty lead wire on spider prevent short circuit and melt down
* Dome shape dust cap design
* Low carbon front and back plate
* Vented magnetic gap technology(VMG technology)
* Laser etched, machined and chromed back plate
* Handle up start 15,000Watts in 3 second short burps
* Custom matching impedance to amplifiers
3. Description/Condition:
BRAND NEW, got them from another member locally who bought them new, he never used them, I never used them, they just changed homes locally. The bottom of the motors are clean, the picture just shows the reflection of the dirty box they were on.
4. Price: :
$300 plus ride each. Will go lower for both.
5. Pictures:
[br][/br]
72Impala
72Impala
Clarksville, TN
72Impala
