2 sundown 18's and 2 saz3000's
how many sqft? and how much for sqin of port?
and what should i tune to?
i wont to put up good numbers at comps but be able to hit the lows and its going in a hatchback car what would be best subs up port up? or subs up port back?
10 cubes tuned to 36hz and use 4 6" aeros..what dimensions do you have to work with..My 18's on a single 3000D does 150 sealed up in a explorer..
bizzle has his in 10cubes @ 32Hz and did a 148+ off a 3000D. It's a low end monster right now, so he plans to raise tuning 3-4Hz and gain some SPL...
Yes he does and tuned to 32hz those nightshades sound outright ridiculous..I am tuned at 36 and do 150 sealed up on shitty electrical..
10ft^3 @ 32 hz with 120in^2 of port would be killer //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
lmk if you need a design
ill give you the dimm. i have but what is best for a hatch subs up port up or back
i'm doing a very similar setup. 2 3500D's and either 2 or 4 18's. havent quite decided (kinda depends on how much space i can squeeze in there). if i do 2, i'm going 10 cubes with 2 ports tuned to 30 and 40, and maybe a 35 hz port to maybe find a sweet spot. if i do 4 it's 20 cubes walled with the same 2-3 ports. around ~13-14 sq inches of port i think i estimated it at. just an idea to go by.
mecaspl151
mecaspl151
sugervally
mecaspl151
