2 subs-1ohm any suggestions
shellfish
I'm currectly running my BL @ 1ohm of my hifonics
BUT thats not enough! I want to use my treo(once it gets out of the hospital)
to run TWO BLs. Unfortunately my sub is a DVC 2ohm sub and i really like it
and don't want to go through the hastle of selling or trading it.
So is it possible to somehow wire two 2ohm subs to 1ohm off my TREO?
it has 2 channels but the screws are missing from the middle terminals //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
so why do we have this forum? close the ***** down, we've already discussed all the possible subjects on here,
and we'll all just sit and use the search button. And i'm starting to think that questions that accualy require
thought makes your head hurt thats why you ignore them but when a noob comes on here asking about his
xploid with a mtx your the first to tell him to wire the bish with 16g power wire so his car burns down to a crisp
Hey bro, What TREO amp do you have? IF its a mono block, it does not have 2 channels, it just has to sets of speaker terminals for more wiring options. Alot of amps have that now so you are not really missing anything. You can not run 2- dual 2ohm subs and achive a 1ohm load. Your options are going to be run it @ .5ohm or 2 ohm. Most Treo amps are beast and as long as you can keep your voltage above 11volts, i would not hesitate to run it @ .5ohms.
Between dropping your amp to .5ohms and adding another woofer, you should see a nice increase in output.
Hope this helps you out some.. If you want, PM me if you have any questions.
Looks like Sicaudio beat me to some of this.. ..
shellfish
shellfish
Concord. CA
gearhound17
vegang
vegang
