wlmrs 10+ year member Realm Of Excursion 1,218 0 Minnesota Sep 30, 2005 #1 is it possible to wire 2 4ohm subs to get an amp to run at 1 ohm Click to read more...
OP wlmrs 10+ year member Realm Of Excursion 1,218 0 Minnesota Sep 30, 2005 Thread Starter #3 i think if i wire in paralleli can at least run amp at 2 ohms???correct me if i'm wrong
OP wlmrs 10+ year member Realm Of Excursion 1,218 0 Minnesota Sep 30, 2005 Thread Starter #5 thanks cbass
OP wlmrs 10+ year member Realm Of Excursion 1,218 0 Minnesota Sep 30, 2005 Thread Starter #6 i guess if i'm gonna run to 12's,to get a 1ohm amp load,what ohm subs do i need to run and how to wire them?
B Blunt 10+ year member 2009 ProStock 0-600 Champ 2,246 83 Somewhere Sep 30, 2005 #7 dual 4 ohm or single 2 ohm if your gonna run 2 subs if one then dual 2
OP wlmrs 10+ year member Realm Of Excursion 1,218 0 Minnesota Sep 30, 2005 Thread Starter #8 thanks blunt
F Flipx99 5,000+ posts Violator of Terms 26,283 35 Building 100 Sep 30, 2005 #9 If they are DVC then you can run them parallel to get 1 ohm.
OP wlmrs 10+ year member Realm Of Excursion 1,218 0 Minnesota Sep 30, 2005 Thread Starter #10 thanks for the info
S squeak9798 5,000+ posts Banned 26,540 97 USA Sep 30, 2005 #11 Are you trying to match subs to an amp that you already own?
OP wlmrs 10+ year member Realm Of Excursion 1,218 0 Minnesota Sep 30, 2005 Thread Starter #12 no i don't own an amp yet
F Flipx99 5,000+ posts Violator of Terms 26,283 35 Building 100 Sep 30, 2005 #13 What do you own? And we can reccomend from there?
Loud3 10+ year member OG 4,998 2 Trampa Bay Sep 30, 2005 #14 no sir 4ohm or 8 ohm Click to expand... 2 ohm, you mean. Run stereo, the two subs together, on a two channel amp would bring the amp down to 2 ohms.
OP wlmrs 10+ year member Realm Of Excursion 1,218 0 Minnesota Sep 30, 2005 Thread Starter #15 i do not own an amp yet,but i plan too soon.will either be a 2 ch or a mono though
