2 SAZ1500's or 1 SAZ3000 ?
well you already have the two 1500s. Just depends at what ohm you need your power 2 or 1 ohm?
also one amp would be easier to wire than two. But the 3000d is also a big *** amp and mounting could be an issue?
I really think it comes down to install.
3000d
Pros, one set of power and ground and speaker hookups.
Cons, rather large amp takes up space.
1500d
Pros, Smaller amps easier to mount in various places.
Cons, two amps require twice the power and ground wires, plus everything else to strap them together.
the 3k will not produce as much power as 2 1500d
we tested the 3k to only do 2700 clean
and the 15 actually did 1600 clean non clipped.....measured with amp clamp and osciliscope..
Twistid
Twistid
in a space out of sound
headbussaboi
michigan born
    May 14, 2026
michigan born
    May 14, 2026
